scfoster
So I've decided one bike is not enough.....
Build #1 has a rack, mirrors, fenders and all the stuff for the daily commute. Looking for a second build which I can use for commutes but want to take on light trails as well. Definitely want it to be somewhat stealthy. No big batteries (commute is only 5.5 miles each way & can charge at work) required.
Here's the donor bike, a GT Zaskar 29er Elite in bone stock form at 28.6 lbs (13kg).
UPDATE:
Here's the bike with the BBS02 installed and the Samsung battery pack. Weight with the battery pack is 45.4 lbs (20.6 kg).
I prefer this configuration of the battery installation... too bad it doesn't actually fit on the bike, There is about 5mm of interference between the battery pack and the frame. I'm loath to start shaving the battery pack to make it work.
So the first question is whether I should go with the 750W BBS02 like my other bike or a MAC 6 Turn Hub motor? The BBS02 has the built in controller with the weight centered. Would also be able to swap out rims/tires for different uses. The Mac Hub would more than likely be faster on the road but the weight will be on the rear and require a separate controller box. The upside of the hub motor would be a real torque sensor in the BB with V3 Cycle analyst integration.
My commute is relatively flat with some hills but nothing outrageous (300 ft - 90 meter elevation change) or long in duration. 2/3 of trip is city streets with stoplights each block. I do end up on the sidewalk for part of it which is accepted by local police as some of the streets are narrow. Lots of potholes and deep ruts (tax dollars at work). Then there is one short section of smooth road with no breakdown lane, shoulder or sidewalk where traffic is moving at 40-50mph. That's the section where it would be safer if I was moving over 30mph (speed limit is 35).
Looking for input on pros & cons of each choice.
UPDATE:
