Hall sensors in 52V Mercane scooter
pellicle
Hi
I had to rebuild my wheel (new bearings) and in reassembly I made a mistake and ended up mashing the hall sensors leads off the stator.
I have no way of knowing what they are as they are proving difficult to remove
So, looking at Ali express I'm seeing these : 10PCS Electrocar Motor Hall Sensor 3144 41F 43F 413 With High Temperature Insulation Sleeve Hall Element Switch 13A A44E Sensor
would these be compatible?
There's quite a few motor hall sensor threads around the forum, some have details on why certain sensors are used in various situations. If you look around and read thru them, they may help you figure out the most likely version to use for your specific motor and controller.
