John in CR
100 TW
I'm changing up my battery pack to mix two 20s strings of old cells with 2 strings of new packs. Since I had a dieing cell in the strings the new packs are replacing, I want to help support the older cells by paralleling all 4 strings at the cell level. It will also make balancing and monitoring easier, because the new strings are much more accessible.
My one concern is whether or not there's risk of significant current flowing through those thin balance tap wires. The strings will be paralleled at the ends, so that tells me that voltage differentials between strings while in use will flow primarily through the very low resistance connections at the ends.
