Recently bought a used Tiff gallop t108. The headlights do not work need tail light works when I pull the brake lever the right hand blinker works properly the left hand blinker blinks sporadically across both sides. Remove the battery cover and upon inspecting the wiring harnesses found that the control wire, headlights, and the marker lights were all three unplugged. The headlights that are on it are aftermarket so I'll have to wire them together I guess but I'm getting no voltage from anything except for one plug. The control plug is four wires two black two red, the plug that comes after that is three wires two red one black, and the one after that is one red and one black. I need to know which plug is which and why the control plug/volt lock being unplugged still allows the scooter to run.
