Electric scooter help hooking up
David90745
Los Angels
Well I'm having trouble with hooking up this scooter I got everything hooked up but on the throttle it's a thumb throttle (3pin) the two wires that or on the cable with it one yellow one green I know one goes to the battery main power and one to the key switch im just learning how to fix electric scooters. Also I forgot to mention at the beginning of the thumb throttle the colors are yellow,red,black and then where those wires connect they add a blue wire then coming up this is my throttle wire that is the throttle wire and when I put the self learning wires together it works what am I missing any help I would really appreciate it
I recommend never trusting the color of a wire (IE never assume black = ground or red = positive). Verify everything with a multimeter. In general a hall based throttle will require +5VDC and 0V/ground and output the throttle signal with the third pin.
