I'll just reiterate most of what I said before.
I can understand being indecisive, I was too before making my purchase.
I would suggest trying to get decisive about the specs you require.
Pack Voltage
Pack energy storage (Ah or Wh's)
BMS discharge capabilities (continuous and maximum)
Once you've decided your requirements, try to find a solution that exceeds them. I would go with the most robust BMS you can get. Having some headroom for discharging current will be handy if you ever want more power
Unless you want a very high Ah pack the only two viable options I see are Headway 10Ah cells or PSI 10Ah cells (14Ah in the near future). For larger packs, search E-S for 'markcycle' and 'hipower'. He is using higher capacity prismatic hipower lifepo4 units and likes them.
Headway cells are about 1/2 the cost of PSI cells and can come with BMS, charger, and fully assembled. If you specify exactly what you want and the product delivered does not meet it, take advantage of the 1-yr warranty and return it.
If the highest performance is required then LiPo pouches or A123 cells should be options on the table, with maximum complexity and price compared with other options.
