Oh, okay.
Just as a thought experiment, let's say you have a cell at 3V and another at 2v. There's a switch between the 2V and 3V cell that basically turns the "parallel" connection on and off and it's initially turned off and the cell's voltage sensor is connected closest to the 3V cell. What would the voltage sensor read when the switch was turned on and, thus, they were instantly put into parallel contact? Would moving the voltage sensor "electrically much closer" to the 2V cell significantly decrease the reading?
Let's say both cells have an equal internal resistance.
(My reasoning goes that the output voltage of the 3V cell would decrease until the difference between the output voltage and 2v create a current determined the 2v cell's internal resistance. Eh, it's hard to express it seems. But, basically, it wouldn't be able to read the 2V cell's true voltage and moving it closer shouldn't create a significant change in the voltage reading.)
But, in the real world, what's the impact of this kind of scenario? *thinks hard*
a123s discharge before the headways, but as long as the headways don't have an output voltage less than 2V, the a123s shouldn't go below 2v as the headways would be charging the a123s at that point. The a123, at that point, however might have significant charging currents and the headways might have correspondingly significant discharging currents which might mean shortened lives but it might not be a significant impact as it could possibly be short lived and the cells wouldn't heat by that much, which is the true reaper of cells.
Anyways, if you wanna, you can get an idea of how much the a123s will discharge at and the headways will discharge at by treating them as distinctly different batteries and putting their data in a spreadsheet I created. It's in the "mixing chemistries for most economic performance" thread or some thread like that at the end. Since we have test data for the headway's internal resistance and the a123's internal resistance, it shouldn't be hard to calculate the necessary data.
