StudEbiker
So I have two chargers here. One charger (from e-bikekit.com) charges my current HIghtekbikes 36v 10ah battery to 42.3v, the other charger (hightek) charges the same pack to 44.88. I believe with both chargers the voltage drops some immediately after removing the charger. I recently purchased one of the 36v10ah packs from EV Components and want to use these same chargers with the new pack. I have read in other threads that the maximum recommended charge on Headway cells is 3.65-3.7. The E-bikekit charger would equal 3.525v per cell and the Hightek would be 3.74v. I am a little concerned of overcharging with the higtek charger, but the voltage drops some right after the charger is taken off so I think it should be okay. Can anyone see a problem with using either of these chargers with the Headway pack?
