Heated Batteries for Cold weather?
Victoria, BC
A couple of years ago I was riding a Luyuan scooter-style ebike in the winter. This was in Victoria BC, Canada where winter generally means the lowest temperature we see is -5Ëš, but normally it's around 2Ëš. This is Celsius. I noticed by the time the temperature was below about 10Ëš, the SLA batteries produced a lot less power at a time, and overall lasted about half the time under load before they needed a rest. Obviously this is because the chemical reaction is slowed... So I never did try it, but I was thinking of using heaters to keep the battery warm. I figured there were two options: 1 place motorcycle heated grip wrap along the bottom of the main battery pack, with insulation below the wrap to minimize heat loss to the bottom of the bike. 2 place newly activated salt-hand warmer packs alongside the second battery, again with insulation. (Those hand warmers are re-usable by placing them in boiling water for a few minutes). I wasn't too keen on the motorbike hand warmers, since they would use a fair bit of energy. But, assuming the battery had been stored inside to start, the heated wrap might make the battery last longer than it would in the cold. I think with insulation and a battery that had been kept inside the hand warmers would have helped too, but not at the expense of battery power.
Any thoughts?
Aluminized EPS foam panels will help significantly. You can easily make jackets for your batteries... the foil should face inward. You can get em at home depot. Extra heat may not be needed.
:D
Yes, heating lead-acid batteries will help significantly during cold weather. Once you get them warm, they will stay warm for quite a while if they have any insulation. I've seen guys use a heating pad (solid rubber type) on the sides of the batteries and just plug it in when the batteries are charging.
I'm in Ontario Canada where it's a bit cooler than the that Pac coast.I keep my sla in the house during winter at around 20deg.Cel. I put them on a float charge for a few hours before going out for a winter ride and I get about a good 20 or so minutes of use out of them before the umph goes.Insulating them will help even more.
Eric
