Samd
I often get asked about whether solar panels are a good way to heat the home. As a result I'm always explaining that it makes little or no sense to convert solar energy to electricity and then to radiant heat given the losses at every step, so less than 15% efficiency is likely overall.
Heliostats however are a cheap way to beam the sun straight in.
Simple version:
http://www.iwilltry.org/b/projects/build-a-heliostat-for-solar-heating-and-lighting/
A whole forum dedicated to DIY Arduino based self adjusting units:
http://www.cerebralmeltdown.com/heliostatprojects/
And a small commercial unit (I recently purchased one) in order to get into it:
http://www.homeheliostat.com/
I'm about to move on to building a large unit using a reflective mylar blanket (ebay survival blanket) spray glued onto a plastic corrugated corfulte/correx panel to see if it works.
Hope the topic is interesting to someone...
Simple version:
