fitek
I'm trying to make sense of how to run numbers for battery charging and what effect charging voltage has.
My observations are that as I increase the voltage of a power supply attached to the pack above the pack voltage, the current that goes into the batteries increases. Of course according to Ohm's law if the voltage increases, resistance stays the same, then current should increase. The internal resistance of the batteries is fixed I assume (does it vary depending on cell voltage or discharge/charge current?).
I've read in many places that the charging voltage shouldn't exceed some value-- however, usually the battery charging ends up pulling the power supply voltage down to pack voltage regardless of what I set the power supply to. After some time, the voltage does tend towards the power supply setting. If that's the case, then what meaning does the voltage I set on the power supply have so long as I make sure the pack voltage never exceeds the maximum voltage (something like 42v for my pack I think).
Put another way: if, for example, I have 3.7v lithium battery, and I would normally charge it using 4.2v, why shouldn't I apply, for example, 6volts and simply cut the charge off once the voltage increases to about 4.2v? For that matter, with a whole battery pack like my 36v12ah pack and a power supply dumping say 3 amps into the pack (the current limit on my supply), that is only a charge rate of 0.25C-- if I set the power supply to 60 volts, does it matter in any way except that after some time I would start to overcharge the pack?
