Hi,
I hope someone can help with my problem. I just built a tricycle into a electric one for a friend who had a stroke and when turned on it runs very slow once you turn the throttle.
I am using a front hub motor a brushed one poss powabyke, a new controller and new throttle, controller is for a brushed motor. With the front wheel off the ground the wheel hardly moves at any speed ( can even be stopped by hand).
I have so far upgraded the wire I was using incase it was to thin tried a different throttle wired 2 front hubs direct to battery pack and they both turn fast, replaced on/off switch with a battery isolator switch and its still the same .
The controller is a 36v 250w 15a it is a yiyun tech yk71.
I shall give you details of how I wired it I do not have pics.
The wiring code from controller was translated by a tiawanese friend for me as it was in chinese.
Speed limiter black and black, brake yellow and black, throttle red+ black- blue signal, power thick red+ thick black- motor thick blue+ thick white-
I wondered if the motor and power wiring may be conected wrongly (i.e. power is really motor supply ) as she said the translatation may have a mistake which she made. I dont want to swap round and blow it if not
I hope someone can help and its something simple I have missed
Many thanks in advance for any help you can give.
Milly
Milly
