I've just ordered a Trampa Holypro 35 degree Mountain board with Ultimate trucks, superstar hubs with road tyres. My plans so far are along the lines of E-Toxx mounts with chain drive, twin 6374 168KV or 192KV SK3 (or APS 6390 at 170KV) modified GT2B controller from DIY
The ESC and battery is where I get a bit stuck.
I already have 30 x 18650 cells (INR18650-30Q) which I can use but I am unsure if they will provide the discharge I require. I was hoping to run 10S or 12S 4P and would buy the extra cells that I require but as far as I can see they have a constant discharge of 15A and so would only give me 60A in 4P if I have worked it correctly? What discharge would I require to run these motors at full potential?
Also I didn't really want to use a VESC as I have read a lot of stories regarding mountain boards and fried VESC so the next best thing I could find would be an Alien Power Systems ESC such as the evolution series with either 2 singles or a double ESC? Does anyone have any experience with these and do they last? How will this go with braking also?
Was thinking gearing would be around 12 or 13 motor to 60 wheel in order to get a top speed of around 40Km/hour
The other option is to do lower voltage and more cells in parrallel in order to increase the discharge to use these cells but from what I can see higher voltage is better?
Would highly appreciate any advice on which way to go.
Thanks
Thanks
