Hi guys
ok I have read previous posts about ecrazyman controller mods
I have a ebike with geared brushless motor like bafang I think, 36v10ah lion pack and standard controller.Want to use 48v battery, opened up controller(pic below) main filter caps rated 470uf 50v and Fets are p65NF06 (rated to 60v)
So I assume I will need to upgrade these components! I understand that 48v lion pack will actually be closer to 55v when charged, so can I get away with main filter caps at 63v?? and does anybody know what fet I can use with a higher rating and preferabley easy to obtain at local tandy (jaycar here in Australia)
And finally have I missed anything is there anything else I should worry about??
onboard regulator appears to be LM317 I assume if i increase total input voltage this may mess up the micro positive rail (I am assuming that is mainly what this regulator is for??)
hoping to get away with filter cap upgrade only, 36 to 48v increase of 12v
What do you think??
thanks in advance
What do you think??
thanks in advance
