matth53
Hello, I recently had my BBS02B controller seemingly fry so I bought a new one. However, it won't turn on. I want to check if the DPC-18 display also fried so I got documentation of the 5-pin green Higo cable plug for the display. There is a PL pin and an P+ pin, and apparently pushing the power button "shorts" these two cables, thus turning the controller on.
So I took a multimeter and inserted staples into these two pinholes, and measured the resistance with the ohmmeter. When power button is not pushed, I get OL (open loop). When I push the power button, I get about 2M ohms. I would think it should be <=10 ohms, but the power button cable also goes through the display and there may be other circuitry inside affecting this. (The cable with the 5-pin Higo comes out of the display and is not directly connected to the power button.)
Does anyone know anything as technical as this? I just want to confirm if the display is dead before I throw in another $100 for a new display (in case the problem is actually that the new controller is just dead from the box).
