JakeTheDog420
- Joined
- Jun 8, 2016
- Messages
- 10
Hello all!
First let me introduce myself to the forums, my name is Brad. I have been thoroughly obsessed with the design and development of this project now for the past several months.
The end goal is having both myself and my girlfriends bikrs converted to fully electric bikes with batterys of at LEAST 9ah.
I purchases a few cheap Chinese cells to play around with knowing they will probably short or die and was basically just a test to see how it all goes together.
I managed to blow my first BMS with them! Aha
Anyway, now after realizing my mistake on the wiring of the BMS and altering the overall design of my project to fit in with a few educational videos I watched I would just like to know if everything will go well with my proposed design.
In the picture you will see two things. First is a diagram I made of a working 13s2p pack. That is the proof of concept. It shows both the front and then if you imagine flipping it over so you can wire the bottom halve too.
The second set in tbe image is the front halve I propose to do. The overall cell count is 52 so from my understanding of things I've simply increased the numbee of cells in parralel and as long as I weld everything as proposed it should all work as expected?
Would appreciate anyones help who has more of an understanding than I do myself.
Thanks for taking the time to read my slightly long post!
Regards,
Brad
Regards,
Brad
