Uncle Ron
icecube,
Thanks to your and others help, I think that I'm starting to understand the broad outlines of the current LiPo state of the art. Cudos for your help. I'm not liable to follow your path because of the inherent dangers of the battery chemistries you're working with, but I can understand from your explanations how these batteries can be used safely by taking great care in their construction and monitored use in the e-bike sphere. Yeah, I'm a bit intimidated. (g)
Thanks again!
Thanks again!
icecube57 said:Well assuming you have a programmable controller You could program the LVC to where the cell stays at a safe voltage during discharge when this is combined with Lipo Buzzers you shouldnt reach the bottom of the pack.
If you size your pack larger than what you can use... You will never reach the bottom of the pack.
If you have a simple speedo one of the most simple ways to ensure you dont over discharge is to automatically factor 1AH a mile. 10 Miles 10AH. Thats worse case senario and you probably will have plenty of capacity left but
If you can afford a Cycle Analyst atleast buy a Watts Up Meter or a Turnigy Watt meter. This will help you on your ride.
You could use an RC charger with balancing functions(1 Unit). The RC charger should be able to charge and balance a pack with a few button presses and automatically shut off. This option you can wire 1 plug for plug and play. There are AC charger units and there are DC units requiring a power supply. I would get Mike an AC unit. It may have a low wattage like 50-100w but if you are charging overnight and dont mind waiting 4-5 hours then this is perfect.
If you use a CC CV charger which means constant current constant voltage it will charged up to a set voltage on the charger and end indefintely float at that voltage. When used with Battery Medics you can balance while its charging. That is if its needed. This also can be wired into one plug for charging and balancing if needed.
I probably would use an RC charger for Mike.
Both routes are intimidating but can be simplified if you take the time and make the harnesses.
