High Amp Master Switch
chvidgov.bc.ca said:
http://lunacycle.com/connectors/xt90-connectors-with-pigtails/
These spark arresting connectors come with the pigtails, so you don't have to solder the wires to the pins. Easy to slap Andersons on the other ends of the pigtail wires.
They really work!
whats the problem to solder wires to a pin? 60+watt iron and 3 sec to solder
Just dont forget to use flux otherwise you will burn plastic on connectors
ps I use Rosin Paste Flux #135 for $8.49 and Weller SPG80L Marksman 80 Watt Iron for $26.60
12V 200A should work with goped 32V80A setup but I dont like the way this switch is done.. and this connecting pin
