High balancing voltage damaging batteries?
magudaman
Bay Area, CA
Well I finally got my BMS (16s Headway/Ecitypower) hooked up to my 16s2p Headway pack. The pack is a bit off balance right now and has actually turned off the charger due to cells hitting the 3.9v limit. To balance I am reading I need to connect my Variable power supply to the pack set it at 58.4 and let it sit for 15 hours. This will slowly bring the pack up to 3.65v per cell and and hold them there while other cells come up and it bleeds off the excess on those cells. The balancing function instead of comparing to other cells just bleeds when the voltage reaches over 3.65v.
My question: Isn't holding the cells at very little current at their peak voltage for so long damaging? Ie holding a cell at 3.7v for 13 hours at 100ma. Most charger have a circuit built in to avoid this and kill the charge when it hits 100ma or what not. It also would seem to be pretty damaging when cells jump up to 3.9v occasionally or sit just below that for 40 minutes! I'm not impressed with this BMS at all and will be looking for a Gary/Fecter BMS from now on!
Once a battery reaches the charger voltage there will be no current flow, so no letting a LiFePO4 cell sit on a charger at 3.70V won't damage it. Once all of the cells in a pack are over the balance point of the BMS you should however disconnect the charger and let the BMS bleed down the cells to the balance point. Also while a charger's LED may go green it doesn't necessarily mean it has shut off current flow, in fact most of my chargers simply park at their designed terminal voltage and current continues to flow until it reaches close to zero when the pack voltage matches the charger voltage. That's also why I generally will leave the pack connected for a period of time after the LED turns green.
BTW, one of the best purchases you can make is a wattmeter, with it you can not only monitor your use when riding but hook it up in-line when charging (I put Andersons on everything to make that easy) and you'll be able to monitor that as well.
-R
PS, if your cells are way out of balance it will take a long time sitting on the charger to bring up the low cells. Also an unbalanced pack will cause some cells to go high and trip the BMS high voltage detect which will in turn open the charging circuit. When this happens the charger's LED will turn green and you might think the battery is charged and balanced when it isn't. Therefore do what Ypedal said and bring them up with a single-cell charger first or be prepared to wait a long time.
Ypedal:
Yah that might be a solution here because I'm really not see a whole lot I like on the BMS market right now.
Russell:
Well I pretty sure this is not true. The battery's nominal voltage is 3.2v so if the current is zero that is where it will naturally sits. It takes some level of current to push the battery up to 3.7v. Most lithium battery chemistries have a cut off amperage of C/20 maybe it was C/25 during their charge. You can not keep a float charger on a lithium battery.
There was quite a bit of good info here when I was looking for a decent reference: http://www.mpoweruk.com/chargers.htm
Constant-current Constant-voltage controlled charge system. Used for charging Lithium batteries which are vulnerable to damage if the upper voltage limit is exceeded. Special precautions are needed to ensure the battery is fully charged while at the same time avoiding overcharging. For this reason it is recommended that the charging method switches to constant voltage before the cell voltage reaches its upper limit.
The charge voltage rises rapidly to the cell upper voltage limit and is subsequently maintained at that level. As the charge approaches completion the current decreases to a trickle charge. Cut off occurs when a predetermined minimum current point, which indicates a full charge, has been reached. Used for Lithium and SLA batteries
The BMS really need to turn on much sooner at say 95% DOD and balance to the lowest cell instead of shaving off the highest cells at the very high peak of the charge.
magudaman said:
Russell:
Well it is the truth. First of all when talking about charging batteries you have to understand that each chemistry has different characteristics and charging requirements however there are also basic electrical principles too which you need to understand. With respect to liFePO4 cells the generally accepted "fully charged" voltage is 3.65V/cell however they are 99%+ full at around 3.40V.
When you start charging a LiFePO4 battery your charger's voltage will adjust to a level which maintains a constant current until the battery is about 95% full at which point it switches to constant voltage (again this is for LiFePO4, other chemistry profiles are different), for a 16 series pack this can be anywhere from 57.6V to over 61V depending on who supplied the charger. When in this constant voltage mode the current continually falls while the last 5% of the charge is supplied to the battery. Most chargers are adjusted to show a "green" fully charged condition when the current reaches a predetermined setpoint which again varies but as an example let's say it's 0.200A. Now some chargers may turn off but none of mine do, instead if you leave most connected the current will continue to fall towards zero as the battery voltage continues to slowly rise to match the charger's output voltage.
When I'm balancing my pack I leave the charger connected until the current reaches about 0.040A (40mA) as indicated by an in-line wattmeter. At this point the average cell voltage will be approximately 3.70V (this will vary depending on the absolute charger voltage). My BMS will balance to 3.60V so at this point the shunt resistors on it are a little warm as they are trying to bleed the excess voltage from the cells to get them to 3.60V, however since the charger is still connected they can't. If I would leave the charger connected that little 40mA or so of current will continue to flow, the cells will remain at about 3.70V and the BMS shunt resistors will constantly be trying to bleed the cells (assuming of course a "bleeding" type BMS) so they will continue to generate a little heat. When I finally get around to removing the charger the BMS will finally be able to drain the cells to the balance point so when I check the individual cells voltages in 15-20 minutes they all read 3.60V+/- 0.01V. None of this will hurt the battery or BMS.
One way I could damage the BMS is to overwhelm the shunt resistors. On my BMS the shunt resistors are tiny so if I cranked the charger voltage too high I could burn them up. Assuming the BMS can handle it however raising the voltage to 3.8V/cell like Ping does can result in quicker balancing though it also risks more BMS cell overvoltage trips which usually occurs at about 3.90V.
Once again what I have said above is for LiFePO4 with a bleeding BMS, other chemistries will differ. For example when I charged LiMn Bosch Fatpacks the switchover from CC to CV would occur when the battery was 80% full with the CV phase lasting much longer as the current decreased toward zero. I set the charger for 41.3V for the 10 cell pack and when the charger reached the terminal voltage the current would drop to essentially zero. I have to stress this; when the battery reached the terminal voltage of 41.30V there was NO further current flow. I could have left the charger connected forever with its output at 41.30V and the battery at 41.30V and there would be no problem because there would be no further current flow between the charger and battery and NO trickle charging going on.
With Lithium you DO have to ensure that no cell goes too high, in the case of my Fatpacks with no BMS I simply used a charge voltage of 4.13V/cell instead of the normal for most lithium 4.20V. The best way to keep cells from going too high while charging them in series is to be sure the cells are matched to begin with then balance them and keep them balanced. LiFePO4 is so darn safe because they are also much more tolerant of overcharge than other li-ion cells. For example I looked up the specs for my pouch type cells and the vendor specs a 4.2V maximum. If you have a BMS it will generally fault and open the charge circuit at around 3.9V thus keeping the cell from ever reaching this maximum.
-R
The charge voltage of 3.65V has some margin for error such as charging at low temperature where 3.65V is a significantly higher SOC than it would be at 20deg C. A cell hitting 3.9V is not going to significantly shorten the cycle life it's just done occasionally at normal room temperatures IMO. Once the back is balanced, it should no longer hit the HVC. Best to avoid more than 80% DOD to avoid unbalancing the pack.
If you have a variable voltage PSU, I would suggest you either set the voltage to a level where the pack is only drawing about 200mA and also check the voltage on all the cells and only set the voltage or current to a point where no cells are going much over 3.7V. If you can current limit, adjust the current limit to some figure around 200mA or a bit less and then adjust the no load voltage to 3.65V times the number of series cells. This will allow the BMS to do it's job properly. It could take a very long time to balance the pack if it has cells at significantly different SOC. Alternatively hook your PSU to any low cells and bring them up individually to 3.65V. Another trick is to put a series resistance in line with the pack with the standard charger. This will taper the current during charging, again allowingh the BMS to do it's job. Alternatively charge the stragglers individually if you the facilities.
I have heard of many instances of headway packs being very out of balance. Unfortunately the BMSs and chargers are only really suitable for a reasonably well balanced pack but should be able to maintain the pack in balance. It's not a major
Typical Chinese BMS has these paramters:
2.0VLVC
3.9VHVC
3.7V balance voltage
0.08-0.2A balance current for small to medium sized BMS as typically used for 10-40Ah pack size.
Cell man speaks the truth, and Russell too. 3.2 v is the nominal voltage, so you got a bit confused about the "charged voltage" number which is between 3.6 and 3.7 on most lifepo4 specs. Ping goes a bit high on his to make the bms balance faster for sure, most go about 2v less on a 48v pack.
Cell man is really right about 80% dod. That is exactly the number I found true on my pings. 80% dod or less, I can go thousands of miles and never get the pack out of balance. Run till the bms trips and it will take several cycles, or lots of time left on the charger continuing to balance to get the pack back to normal. But I don't hesitate to do a 100% discharge when I need to. I don't even think of turning off a controller and pedaling, but I'll slow down if I know I need to stretch the range.
The same thing applies to discharge rates. Whatever the c rate is, discharge at half that if you can. My pings, for instance, can get very unbalanced if discharged at 2c for only 30% dod.
While cell_man makes good points I too am uneasy with the Headway BMS holding the cells at 3.65-3.90 during balancing, so I only go that high after 50-100 cycles when the battery becomes noticeably weaker at the end of the ride.
Computer control would allow balancing at any voltage, say 3.50. For longer life you could use this as the upper limit, or when more range is needed turn off all the shunts and continue the charge until any cell reaches 3.65. Graphs of the individual cells during the final topup might be a good indication of their condition. If I ever get something like the Atmel ATA6870 kit that's one of the things I would like to explore.
I personally can't see why something as simple as a closed contact from the BMS when any cells reaches the balance voltage couldn't be used to reduce the charge voltage to 200mA or whatever value suited. It doesn't strike me as a particularly difficult thing to achieve, but unfortunately you get BMS manufacturers and you get charger manufacturers and they don't necessarily talk in most cases :?
I do agree that it's not ideal to have cells above 3.7V but I also think many people worry too much. It's a compromise that has to accepted unless you start paying for more sophisticated solutions and many already think a standard BMS is no more than an unnecessary part which the manufacturers/suppliers use to squeeze more money out of them :)
I'll have to have a play sometime to work out some suitable resistor values and ratings that could be put in series during charging to help the pack balance properly for a pack built with cells with varied SOC. Unfortunately the bloody chargers often have some stupid so called smart feature that stops the charging once it even reaches the max shunt current of the BMS, so that might not even work in all situations either.
