High-Power 4S 150A LiFePO4 Battery Pack – Advice on Connecting the Cells
pumba990
🧲 New user
United Kingdom
Hi everyone,
I am trying to build a high-output power 4S battery pack using Lithium Werks 26650 cells. These cells are rated for 150A for 10 seconds, and I want to connect them in a way that can comfortably handle this current.
People often use 0.1mm or 0.2mm nickel strips, but I don’t think that would be a good idea for this application. Even when stacking multiple strips, I am concerned that hot spots could form, potentially damaging the pack.
What would be the best way to connect these cells and handle 150A in a DIY project? Keep in mind that the use of exotic equipment is not an option.
Cheers
I would check out the "copper nickel sandwich" thread. There are a number of ways to use the nickel to connect to the cells, and and then rely on copper to carry the current over the the next cell.
For 150A per cell, i'm afraid it will be hard to avoid "exotic equipment". At the minimum, you'd need K-weld and a really good power for it to weld copper-nickel sandwich like Paul mentioned.
The only alternative option is soldering, either copper braid or straight wire. This is much more risky, though, as you need a very high power soldering iron and a lot of care. A TS100 could maybe handle it, but ideally you'd have 100-120W, proper tip and good temp cotrol.
Regardless of the method used, be prepared to scrap at least a couple cells for testing.
