Analogrider
🧲 New user
Hi,
My wife purchased an Envo Lynx 20 ebike directly from Envodrive.com and it keeps blowing the high side (positive) mosfet on the yellow phase wire.
The bike uses a Kunteng KT36SVPRCD-CBWF06L controller. Specs in photo below:
The motor is advertised as 500watt but based on the controller seems more likely to be 350?
Battery is 36V 12.8Ah.
It's blown the same mosfet on 2 (probably 3) controllers now. I didn't get a chance to confirm on the first controller, as it was replaced under warranty but on the 2 subsequent controllers I used the troubleshooting method outlined on the Grin website and traced it to the highside mosfet on the yellow phase wire. I salvaged a good mosfet from one of the controllers, tested it, replaced the bad one in the other controller, and it work's fine, so that the rest of the circuit seems to be ok, it's just that one mosfet.
Every time it's happened basically the same way: from a standstill, with no one actually sitting on the bike, the throttle is engaged to the maximum setting. Basically, we were using the throttle to try assist getting the bike up our front steps. The first time just on the bare stairs, the second on a ramp, and the 3rd time my wife caught the throttle on the virgina creeper that grows on our fence.
All 3 controllers were used for a few days before blowing, under load, for a dozen or more kilometers of riding. They were primarily used only via PAS but the throttle had been tested.
After the second controller blew, I modified the settings to limit current to 75% of the maximum. (C5 set to 5 on the LCD3 display). It still blew.
It seems to me that this shouldn't overload or overheat the mosfet? Is it the sudden inrush of current that is causing this? Or is there a bad component or short in the motor or motor cable on the yellow phase wire?
I'm new to ebikes, but know a bit about electronics and have been a home (traditional) bike mechanic for over 10 years.
This forum has been a great firehose of information getting me up to speed on ebike tech and I greatly appreciate it. I look forward to your insight, let me know if you need any additional details or photos. Thanks.
