ElectricGod
It wouldn't be hard to make a battery tube. All you need is some aluminum or brass tube. Brass can be soldered easily so that may provide some better options since brass and copper fittings that are threaded are really common at your local hardware store. Some thin walled brass tubing of the right ID would be fairly light weight, but would make easy to build battery tubes. You would need to have some strong springs so the cells stay planted end to end firmly. 6+ amps made up by just butted up batteries is asking a lot if the contact isn't really solid.
32650 cells...Obviously this is for a flashlight, but you get the idea. I suppose if you used these batteries you wouldn't need a BMS or a balance charger since they have a management board built in. Just apply the correct voltage to the entire pack and everything gets charged and balanced.
http://www.ebay.com/itm/TrustFire-32650-3-7V-6000mAh-Rechargeable-Li-ion-Battery-w-PCB-Protected-Board-/351341613979?hash=item51cd97939b:g:SksAAOSwdS1VA-Xe
Regarding Hobby King...
They pretty much suck when it comes to having accurate listings of their inventory. I purchased 4 zippy 8000mah 6S packs in early December and I'm still waiting for them with no ETA or even a guess of when they will ship to me. Every time I talk to their CS people they tell me they don't know when they will have more in stock and can't be bothered to ask their purchasing agent when they will. When I purchased the packs they showed more than 10 in stock. Then a week later I get an e-mail saying they are out of stock. You could say that I am pretty much 100% pissed at hobby king now and seriously thinking that I will never buy from them again and certainly wont have anything positive to say about them! I haven't purchased very often from them, but the first time I lay down $500 they completely screw it up.
