4LivesPerGallon
- Joined
- Jul 2, 2015
- Messages
- 305
This information comes from a battery guy in our group who has been on TV and magazines for his 'impossible' battery innovations.
https://www.flickr.com/photos/10670363@N05/2612151162
When lead acid batteries (Gel, AGM, or flooded) get older, their capacity diminishes. Measuring remaining capacity (Amp Hours) is a complicated and difficult process. We own several, costing from US $125 to $450 each, and each one either specialized for a type of lead acid battery, or requiring a selection for battery type. All are computerized, and all are easily destroyed by reverse polarity, so we don't lend them out.
http://www.midtronics.com/shop/prod...idtronics-pbt-200-professional-battery-tester
Lead acid batteries are destroyed by fast charging, unless it is a very expensive type that requires a high charge rate. To our knowledge, only the very expesive Hawker Genesis has the lead purity for high charge rates, i.e. minimum 4C. We had one experiment scooter with the Hawkers (Cdn $600 for 48V, 16AH) and it worked very well, full charge in 35 minutes, and could sustain high discharge continuously, without "running out of breath" unlike other Sealed Lead Acid batteries.
http://www.evalbum.com/4413
HERE IS THE PROBLEM: As capacity diminishes, the charger should reduce its charge rate also. Unless you have Hawkers, the charge rate should be no more than 1C rate. Illustration of the problem: On a 48V pack, if the remaining capacity is only 12AH, a 4amp charger will charge at a 3C rate.
Years ago, we charged a high-discharge rate (not cheap, but not Hawkers) 24V Ego scooter pack, tested remaining capacity 25AH at 15AH. Yes, it worked, but after about 30 full and partial charge cycles, the battery started to "run out of breath", and needed 20 minute rest periods.
ALSO, lead acid battery chargers should have selection buttons for Gel, AGM, or Flooded type of battery.
In summary, with batteries, nothing is simple, even with lead acid.
There are some retired BC fishermen who know how to keep flooded lead-acid batteries running for 20+ years. They did not share their secret to us, unfortunately.
There are some Chinese devices that claim to "desulfate" lead acid batteries. Motorino in Vancouver sold one that is easy to attach, inline.
http://www.motorino.ca/motorino-XPseries-owners-manual-01.pdf
We also have a "smart" Chinese battery charger that uses "reverse voltage"(?). Came from ebay, no English at all, no instructions, but seems to prolong battery life. Only 2 sets of AGM batteries used up on a 2008 Motorino scooter, which was also connected to the Motorino desulfator.
LOOKS LIKE THIS ONE, BUT 48V, NOT 36V:
http://www.aliexpress.com/store/pro...battery-charger-of-NPT/810452_1788851241.html
UPDATE: Here is another Chinese supplier, with all voltages. Note that this battery charger takes longer to complete charging.
http://www.ecvv.com/company/ultipower/products.html
