Hi guys
My friend and I are trying to get his ebike up and running. The motor is a hub motor with built-in controller. The wires from the motor run from the rear to the front handle bars. The OEM LCD that in on the handlebars seems to be damaged. There are wires going to that LCD panel which shows the basic info (speed, odometer, battery indicator, etc)
There are seperate wires going to a small set of buttons on the handlebar as well that are not attached to the LCD display that turn on the bike and also +and- buttons
Since the LCD panel is damaged and does not turn on, is there a way to bypass it to get power? The battery is fully charged but the power button does not power the bike on.
Any advice is greatly appreciated thanks!!!
A little update..I seen these wires going into the LCD panel. When I removed the back cover I seen : "TX" grey wire, "RX" white wire, "B+" pink wire, " K " yellow wire and "GND" black wire on the pcb
Would any know what the TX, RX, and K stand for?
