I had a rickety old bike with a BBS02 750W motor and a 48V battery from Luna cycle. They have worked great together for years. A friend gave me an old Specialized mountain bike so I decided to switch the system over to this newer rig. Everything seemed to have gone well but when I plugged the system in I seemed to have killed my battery. I am nearly certain the battery was topped off before the switch (which only took a few hours). I had the controller hooked up then I plugged the Anderson connectors together (I may have heard a small arc, maybe not). The display was on for a second then off. Then it would not turn on again. This battery has a button you can press to see what the charge level is. I've never really used it though. But pressing this button seems to indicate the battery is essentially discharged. But putting it on the charger doesn't do anything (as if it were already full)
I seem to remember using a multi-meter on this battery's leads and getting 51-53V. Now it reads 0V. I cracked open the case to see if anything was obviously wrong. Everything LOOKS okay but still no voltage across the internal leads. I found this one tiny wire that MAYBE has come undone. I tried to get a shot of the little guy. In the attached photo you can just see it dangling above the left end of that label.
I'll try Lunacyle as well but thought someone here might be able to help also.
Thanks!!
Thanks!!
