How do I connect these? Bullet connectors one end, bare wire other end
depends if need to disconnect
if no disconnect use quality splice
if yes look here
https://www.ebikes.ca/shop/electric-bicycle-parts/connectors.html
can use automotive bullets to match current connector
although many would not recommend
i would use anderson power pole
too bad this thread directs to bad powerwerx link
https://endless-sphere.com/forums/viewtopic.php?f=2&t=17969
read stickies and search "connectors + wire"
Are you better equipped to solder, or to crimp? If solder, get XT60 plugs and install them. If crimp, use Anderson PP45 plugs.
If you want to do this cheap and dirty, use butt splices to join heavy gauge SAE quick disconnects.
