monster
- Joined
- Jun 17, 2007
- Messages
- 1,411
hi
i was testing my data logger today and making a voltage divider for it. the Velleman pcs10 is really good data logger!
anyway, i used ohms law and realised that when putting resistors across a 81v battery -you better use high ohms or its gonna go bang. so i picked the biggest resistors out and made the voltage divider out of them. when i came to measure the volts drop across the different resistors some thing really weird happened. it was like ohms law didn't work any more and i had to check and re-check to make sure i wasn't seeing things. the volts dropped across the individual resistors did not add up to the total battery voltage.
eventually i tried another meter and the two meters gave different readings? suspecting the battery, i tried again with a fresh meter battery -no change. things got weirder when i tried connecting the meters at the same time, and one meter started to affect the others reading. i figured it must have been something to do with how the multimeters work? and the really high resistors i was using were messing with the meters. i reduced the resistance of the voltage divider and all was well after that.
