Peter Sternersson
My first electric bike build is coming to an end, I got my BMS Battery Alloy Shell charger yesterday along with a "battery management system"
http://www.bmsbattery.com/bmspcm/323-17s26s-24a-max-discharge-current-bms.html
I connected everything up according to the scheme found where I bought my batteries (they have the exact same BMS, but a better wiring diagram).
http://www.ev-power.eu/docs/pdf/GWL-SBM-Product-Specifications.pdf
Hooked the charger up and it started charging for a minute or two. My cell voltage was around 3,3V when I started (53V total), and the charger quickly reached 57,6V and shut off.
After a minute or so it turned on for 5sec again...
When I took the pack of the charger it read 53,X Volts still. Perhaps this is normal, I understand that the voltage will drop some as soon as you take it of charge, but 5V??
How exactly does one of these BMS boards work?
I was under the impression that the MOSFETS on the board "portioned" out the Amps to the lower cells or something?
Or does the charging stop when one cell reaches full voltage, and then the effect resistors burn that cell down in voltage and charge everything up again?
The later whould mean that you cycle that one cell much more then the others as that cell will also take charge much faster than the others as well?
Also, how does the low voltage cut off work? If one bad cell reaches the cut off way before everyone else, the rest of the capacity in the battery can not be used??
