Jim Subzero
- Joined
- May 18, 2020
- Messages
- 24
I just built a 14s16p 40 Ah [edited] battery. When I put it together all cells (18650) were very close in voltage. I randomly tested a sample for capacity and found them close. I found one dead cell, and it could not be rehabilitated. A few cells were a couple of tenths of a volt below the storage voltage, but cycling them and testing their capacity showed them to be the same as the others.
With the wiring and packaging complete I put it on the charger. The BMS used has a bluetooth radio enabling me to watch the voltage of each parallel group. Group 10 charged faster and reached 4.2V well before the others. Group 4 lagged a bit behind the others. The BMS started balancing. I saw G10 briefly touch 4.25V than fall back to 4.2V a few times during this initial charge.
The next day I mounted the battery on the bike and went for a ride. The bike behaved well, a bit friskier than with its 48V battery. However, G10 instead of being high was a half volt lower than the rest. This is despite the BMS balancing, or so it says. Recharging does not change G10's lagging voltage; it stays roughly ½ volt lower than the rest.
What is wrong? Should I worry?
By the way, I need to mention a crucial fact. Each cell has its own pcb to protect it from over voltage, under voltage, and over discharge rate.
I speculate that perhaps one cell in G10 is bad somehow, but I have no idea what could produce the observed over and under voltage problem for that group. I am new to this.
