I missed this till now. To answer the original question about how good the BikeE is at higher power/speed...I think I'm qualified to answer this.
I converted my BikeE back in 2014 and have been riding it almost daily to commute to/from work ever since.
https://endless-sphere.com/forums/viewtopic.php?f=6&t=57751&start=275
It's been through a few variations in power/speed with the fastest being when I had it running on 16S LifeP04 and my (unbeknownst to me at the time) faulty 6Fet (Mini-monster) Infineon controller with no current limiting and 120% speed mode enabled. That let me push over 3KW and 65Kp/h through it.
Also at that time, the battery was mounted over the rear tail leading to quite a few unintentional wheelies. :lol:
That was nuts, and since then I've toned it down a bit. In it's current form I fixed most of the original issues to running this thing at decent power/speed being:
-Internally mounted battery to fix the weight distribution/handeling
-Smooth tune-able, sine-wave controller to prevent steep throttle ramp
-Big volume tires to absorb big bumps and run lower pressure (35PSI Rear, 25PSI Front)
-Extra/additional padding on the seat. I used a neoprene cover and put padding between it and the original seat.
-Clipless pedals. A big help in preventing leg suck which thankfully I've only experienced once and is really bad.
-Adjust the seat as far forward as possible while still being comfortable/safe
-Ride very cautiously, especially on or around;
--Loose/wet surfaces
--Other people (especially children)
--Learn where big bumps are on your route and either avoid or slow right down for them
--Periodically 'reset' your sense of speed by taking it easy/slow for a day or two
-Adjust or limit your power/speed to something sensible. For my BikeE I've settled on around 1250W/50Kph.
-Use regen, but tune it properly. This is a massive help in stabilising the bike when it gets unsettled and you need to slow down quickly. Also saves on brake pads and gives a bit of extra range.
With all the above, in the 6 years I've been riding my BikeE around Canberra, I've never had a collision with another person or object. Only crashed 3 or 4 times and was able to ride away from all of them.
I am thinking about making a few changes to my BikeE to slightly reduce the speed a bit more in order to extend it's range, but not sure yet.
I'm also working towards converting a (non-electric version) Giant Revive. I'm thinking about making it more off-road capable, but it will still probably have a top speed of at least 40kph and at least 1000W.
Hope that helps. Happy high power/speed recumbenting.
Cheers
Cheers
