John in CR
100 TW
I always understood that if given an option, short battery leads and long phase wires is better than long battery leads and short phase wires. I question this conventional wisdom with moderate and high power rigs, since phase current is so much higher than battery current.
I've also heard that battery loop inductance can be a problem for controllers. I'm working on battery packs right now that will be installed within the bike frame, so they will be long and relatively thin, and installed in multiple areas of the bike (primarily the top tube and downtube) instead of a centralized block like with typical ebikes. For long rides a range extender pack would go on a back rack, opening up the potential for quite large loops. My plan is multiple long full voltage strings with cell level parallel structure connected between these separate packs. I realize that I shouldn't have my battery leads or packs form a loop around the perimeter of the large triangle.
My question is can I organize all this wiring in a manner that minimizes the loop inductance? I realize that I shouldn't have my battery leads or packs form a loop around the perimeter of the large triangle, but should I make a concerted effort to run the +/- leads as close together as practical to minimize the loop contained within each pack's flow? Is it significant enough to worry about? Are extra capacitors a sufficient solution? Will these long parallel wires for balance tap purposes play much of a factor if the current through them is low?
My main bike has been running with a conglomeration of separate packs in parallel, but I haven't installed extra caps on the battery side. Running at 8-10kw could the battery loop issue be part of what kills my controllers? What size and type of caps would be appropriate?
