wesnewell said:
You need to do some research on this. 100 ft. lbs is on the low end of the scale for a M14 nut. Max is ~200 ft. lbs. if you strip them with 100 ft. lbs., they are worse than garbage. They should be class 10 -12 nuts.
http://yetmans.mb.ca/kohler/page3/page3.html
wesnewell said:
All I can do is provide my experiences and the torque specs.
To make the point again - your 'spec' is inapplicable. It is based on an assumed grade of 10-12 for the nut/axle which is completely arbitrary. You are simply choosing a grade that when mapped through the 'spec' gives the torque you wish. Chose a different grade and get a different torque - this isn't a 'specification', it's an assumption about axle composition and shape wrapped in a bit of tabular sleight of hand; there is no specification involved that is based on factual physical characteristics of the axle... and this is ignoring the differing configuration of the solid bolt and hollow axle (possibly with side cutaway).
Here is a post by Justin
"Thread/Bolt Stripping Test" describing a nut finally letting go at 125Nm (92ftlb).
FWIW - his comment regardling 92 ftlb (lower than your recommendation of 100ftlb):
I couldn't imagine anyone tightening a nut on a bicycle that way,...
In the same post, he tests a Crystalyte axle with conflicting results:
Justin said:
...all of Affliction's (Ben's) comments seem to be with regard to Crystalyte axles. Well we have some of those lying around too. So same test as above was done on a slightly used 400 series rear axle. The peak torque was 70 N-m (52ft-lbs) when the nut started to spin freely. Definitely stripped threads:
We then flipped the axle around to repeat the test on the other side to get a few more data points and get a sense for the repeatability. And guess what, on THIS side of the crystalyte axle, we had it all the way to 130 N-m when the wrench slipped and rounded the nut as above with the eZee axle.
So, while one end of the Crystalyte axle stripped all it's threads at 70 N-m (52 ft-lbs), this side withstood 130 N-m (96ft-lbs), with the threads still almost perfectly in tact:
Not totally sure what to make of this. Either there is a huge variability in the temper on the Crystalyte axles, or more likely I think it is the mechanical tolerances on the axle threads, with one side being a looser fit in the nut and hence much more prone to stripping.
Justin has posted graphs of results of
No-TA Axle Spinout in steel forks showing results using (30,60,90)Nm or (22, 44, 66)ft-lb of torque. The upper limit of 66ft-lbs is very much in line with dogman's recommendation above. The entire page (thread) make interesting reading.
wesnewell said:
If you had an axle strip with only 65ft. lbs of torque then it was defective, either that particular axle or by design.
Indeed. I have two motors with this situation and others have experienced similar stripping due to a design issue as discussed in the thread referenced earlier. These then are production axles that you agree cannot be torqued to 100 ft-lbs... design flaw or not - that's the way they come from the factory.
I have no problem with claims of personal experience but you didn't qualify it as such (initially). Continuing to present your torque recommendation as a 'specification' is IMHO at best misleading. There are many folks reading this stuff who will take such statements and claims of 'specification' as gospel and who may pay an unfortunate price.
IMHO the more conservative torque of 66ft-lbs max used in Justin's tests (and which dogman has similarly recommended) is very much more in line with reasonable practice. Justin's graphs show axle spinout without TAs - certainly using axle nut torque even less than 66ft-lbs is not unreasonable with a TA. This bears out my experience as well (7300mi with a single TA and less than 50ft-lbs at up to 2kW and absolutely no loosening or dropout deformation). A good flush fit for washers, etc without bridging dropout indents/recesses will help minimize loosening.
