Mechdude
Hi all. In my first foray into ebikes I have bought 6x 6S 5000Mah nanotech batteries. However things have not gone to plan, including exploding batteries (Long story).
However I now find myself with several batteries which are significantly unbalanced.
The battery in front of me has voltages:
3.736
3.727
3.742
4.128
4.166
4.186
(This is indicative of about 4 of the batteries)
The charger I have is a Turnigy Accucel-8 150.
If I use the balance mode, it pushes all the cells up rather than balancing, and I find myself exceeding the 4.2 limit.
After a short charge the other nite, I came back to find #6 cell at 4.32 and cells 1,2,3 only just on 4.0. (Quickly turned it off!)
Have also tried the discharge mode and a similar thing happens in that it drains all the cell down, still unbalanced, and the first time I tried discharging it dragged one cell down to 2.8 until the cell dropped out on error. Grrh. Unfortunately the charger does not have the ability to change upper charge limit (4.20) or lower discharge limits (3.0).
Growing to dislike Lipo's!!
I read somewhere about balancing cells on a cell by cell basis, however I can't figure that one out with the charger I have. The lowest charging level it will let me select is 2S which I assume is too high for a single cell.
I find it incredible that Hobbyking sell items that are so sensitive to incorrect use with no instructions.
I can only assume that this unbalance has come from over draining (I bought the cell meters after the fact)
The batteries have probably only seem 3 or 4 cycles.
But I am also hopping that if I can re-balance them that I can get them back to a working state.
Appreciate your assistance, cause I want to get out riding!!
Howard
3.736
3.727
3.742
4.128
4.166
4.186
Howard
