mnikhilesh
- Joined
- Oct 10, 2014
- Messages
- 1
I am building a 14S Lithium-ion battery pack. I will be using a 4.35V max voltage 18650 Samsung cells. To increase the life of cell I will restrict the battery pack to charge each cell only to max 4.0V instead of 4.35 volt. By this way I will loose about 20% capacity and I expect battery life to be extended substantially. Now my problem is I am not very clear how I should charge my battery pack. Normally chargers are designed for charging constant current to 4.35 V and then keep this voltage in constant voltage phase so that charging current decays to very small amount like 0.1C. I can custom order my charger so should I make it so that my battery charges in constant current phase till 4 volt and then switch to constant voltage at 4V and wait the current to decay or should I only charge it with standard charger (4.35V CC) in constant current mode only and once the voltage reaches 4V let BMS cut the charging process.
