safe
1 GW
- Joined
- Dec 22, 2006
- Messages
- 5,681
PUSH OR PULL?
Another question is whether to "push" air into the motor or to "pull" air out of it. One possible advantage of a "pull" approach is that you would be "pulling" warmer air. Now let's think about the physics for a second, which type of air is easier to move, hot or cold? My guess is hot because it's going to be thinner and so you would be "assisting" hot air in moving from a hot and compressed state to a cool state. Hot air expands by nature, so I would figure that the "pull" would be better.
Thoughts?
One other thing is that the outside colder air might be providing more "inertia" than the hot inside motor air so one would want to get that figured out. Maybe thinner air is less able to be moved because the fan relies on "inertia" to generate it's movement? Does thinner air effectively lower the efficiency of a fan?
What comes to mind is that "compressions equals more heat". So in order to compress air INTO a place that is hot you are adding to the heat because you are increasing the pressure. By "pulling" from a contained space that is already expanding due to heat you are working in parallel with what the air already wants to do.
Thoughts?
