So if the fets work at a certain minimal voltage wouldn't it be a problem lowering a lets say 16s controller to a 3rd of the voltage (that's about what I need)?
Wouldn't it be a problem having about 30A and 22v? heating and stuff...
I looked up the page about the voltage dividers posted flagefrog and it's very helpful (thanks man), and I started messing with calculator and in order to get a 3rd of the voltage I need to have two resistors: one that is a certain resistance and the second one half the resistance of the first.
So should I just choose the ohm rating randomly and get another resistor with half the resistance? like 3300ohm and 1700ohm? which are common ohm numbers so I can get exactly half for the second resistor? (looking up eBay)
How important is the resistor's wattage? I see some 0.25w and some 1w (which seem big)...what exactly do I need?
Are there other things I need to consider while buying resistors? what is all that 1%, 5%, carbon etc?
Now the biggy for me...how do I find the place to stick my "super special voltage divider circuit"? I need to find that IN and OUT area to connect into my controller...
Is there a common physical place that it should be at when looking at the PCB? like a spot near a certain big cap or something?
Let's say this is my controller:
https://i.ytimg.com/vi/1PotpG-cVoU/maxresdefault.jpg
which it isn't but I will go through the hassle of uploading a pic of my controller's PCB if it's important to be very specific about the type of controller etc...
Thanks alot so far,
Roy
