izeman
1 GW
some may have followed my thread with my broken mac/bmc motor which had not properly working hall sensors even though lyen's style ebike tester showed them working correctly.
i installed new hall sensors and everything was working again. until the next long ride. near the end of a long steep hill speed became lower and lower and those well known symptoms came back: a weird noise from the motor like a mechanical defect inside the motor. at a speed below 10km/h i stopped because the motor was producing no more power. i tried launching the bike again and it had big problems (me pushing it uphills - not riding it!!). the wheel just didn't start turning from a full stop.
after reaching the top of the hill i tried riding the bike again. the motor 'caughed' a bit but the higher the speed the better it was. it was like cutting and reengaging the power several time a second. after i reached 25km/h the ride was almost totally smooth again and the bike pulled like before until it's normal top speed of 45km/h.
so i don't know why the original honeywell ss41 halls got damaged again (i guess ONE of them) but it something killed it - maybe the controller did it. a new one is on it's way
to make a long story short: i now have those 3 halls laying in front of me and all look good. how can i be 100% sure which one is working and which one is not. they ALL react as the should: with GND and VCC attached they switch between those two when a magnet is moved along and switch back when the poles of the magnet are swapped and done again.
do i need an osciloscope? or are some hundreds or tenth of a volt difference enough to make one hall sensor a good one and one a bad one?
maybe someone can help!
thanks!
thanks!
