Question: For the best hub motor efficiencies; Is it better to limit amps whilst running at a higher voltage, or run a lower voltage through either a lower voltage battery pack or DC-DC voltage converters?
This is a lengthy post, so I'll give the detailed explaining version below, and the short version with the question above.
So I'm planning on building a LiPo pack for my Stealth Fighter some time down the track, and one of my main motivations for doing so was to gain an increased range.
As such I was thinking of making an 18S pack to give 72V hot off the charger. My current pack is 58.4V hot off the charger.
My current pack gives around 55kmh at full throttle, at which it pulls around 1500w to maintain that speed on the flat.
The LiPo pack I plan on building should give around 65kmh at full throttle. I imagine with the increased wind resistance this will mean a higher amp draw in order to maintain that top speed.
At the moment I limit power usage by limiting the amp draw, as do many others. This seems to work ok, but I'm wondering how efficient it really is. According to Justin's Ebike simulator http://www.ebikes.ca/simulator/ hub motor efficiency is at it's greatest when nearest the battery pack output voltage.
So I was thinking, instead of using the CA to limit amps to conserve power, wouldn't it make more sense to use 1 or 2 DC-DC voltage converters to step the voltage down so that the motor can reach it's peak efficiency sooner and easier. This would also create the effect of electronic gearing.
Good idea/bad idea? What are your thoughts?
Cheers
Cheers
