Hub motor is a 1000w yescomusa.
I was riding down a hill pretty fast and noticed in the last second a hard to see rock that was mostly buried in the ground but sticking up a few inches. While turning around it I missed it with the front wheel but it hit my rear wheel and threw the rear rim out to the side.
Not sure if It was because I was looking for stuff after the hit but I noticed a squeaking sound coming from the hub motor. At first I thought it was my suspension but do not think it is because when compressing my suspension while not moving it does not make any noise. It squeaks every second or so. If I grab the rear wheel and push it from left to right it will make a slight squeaking sound. I do not see or feel anything loose.
Bike runs fine and I can get full speed without noticing anything wrong with the bike other then what sounds like a squeaky suspension. I lifted the rear wheel off the ground and gave it full throttle and did not hear any squeaking sound.
To me it seems that it has something to do with side forces on the hub motor. Somehow I think this was after I hit the rock.
Could that hit on the rock that pushed the rear of the bike out, be enough to cause damage to the hub motor? Any way to inspect this damage and fix something like this?
Another important question is if I damaged something could the hub motor fall apart while riding the bike?
