Ratking said:Sahara is getting smaller, Norwegian ice glaciers is not getting any smaller, Australia have record cold weather etc.
Have we done this image yet?
Punx0r said:I'm not saying SkepticalScience is a great reference, but that article claiming to critique it is just an attempt to character-assassinate the website founder. That's not science.
Can you please explain the graph? It appears to show that increased atmospheric CO2 increases radiative forcing, which is a measure of how much of the sun's energy is absorbed by the Earth.
Scientists say a dramatic worldwide coral bleaching event is now underway
Ratking said:And to add a graph explaining why an increase in co2 is not a threat:
http://clivebest.com/blog/wp-content/uploads/2013/02/radiative-forcing.png
Using computer models, the study also discovered there could be a doubling of ice shelf surface melting by 2050, which could quickly drive up sea levels.
This discovery basically tells us that a lot of the damage will be done no matter what we do in the next 35 years, but there's still time to alter the effects of greenhouse gases on the planet in the second half of the 21st century.
Sybren Drijfhout, professor at the Royal Netherlands Meteorological Institute and lead author of the study adds, “There is of course a certain tendency for the whole climate system to become more unstable when the warming gets larger, but we cannot say, ‘as long as it’s this and this much, nothing will happen.’ Every .1 or .2 degrees in temperature is as dangerous as any other, I would say. And that’s the main message of this exercise, or this paper.”
jimw1960 said:Ratking said:And to add a graph explaining why an increase in co2 is not a threat:
That graph is one of the more ingenious anti-AGW arguments. It almost had me until I did a little reading and dusted off my calculus books. The theory represented in that graph purports that, once there is enough CO2 in the atmosphere to block IR spectrum from reflecting back to space, then the addition of any more CO2 (or any other GHGs for that matter) will have negligible added effect. Seems to make sense on the surface, but a simple understanding of integral calculus and thermodynamics is all you need to debunk it. When you look at the Earth's energy balance, the energy that comes in from the sun has to either reflect back to space or something on the Earth (oceans, atmosphere, land surface) will have to get warmer. In a GHG-free atmosphere, the sunlight comes in in the visible spectrum and it heats the surface until it can reflect an equal amount of energy back into space in the infrared (IR) spectrum, at which point no additional warming will occur. You have energy balance: energy in = energy reflected out + energy stored in heated surface. The laws of thermodynamics are satisfied. All is right with the world.
Now let's add just enough GHG to block the IR spectrum from getting back to space. What happens? Surface warms as before, but before the IR can get back to space, it is absorbed by the atmosphere. What does that mean? It means the atmosphere got warmer. Now, to achieve energy balance, it is the warmed atmosphere acting as middle man that is ultimately radiating the IR energy back into space. Can we agree on this?
Now let's test the theory that adding any additional GHG won't have a greater warming effect on the atmosphere. So let's double the GHG concentration and divide the atmosphere into lower and upper slices: sunlight comes in, surface warms, tries to reflect IR back to space, but now the IR is absorbed just by the lower part of the atmosphere. So what happens then? The amount of energy that the atmosphere is trapping from the same amount of sunlight is now absorbed just by the lower atmosphere. Same energy absorbed by less mass means that lower atmosphere has to be warmer than it was with the lower GHG concentration. That means that the lower slice of the atmosphere must be warmer to radiate IR to the upper slice so that the energy can eventually get back to space (unless you want to void the laws of thermodynamics).
So, if you know your integral calculus, which I'm sure you do, you understand that you can slice the atmosphere into an infinite number of small slices, and it becomes a relatively simple integration problem. Integrating the energy balance equation from land surface to the edge of space can be used to compute the temperature at elevation in the atmosphere given a fixed solar input and GHG absorption properties. The math shows that with a fixed solar input, the atmosphere must necessarily get warmer as GHGs are added in order for the energy to be reflected back to space, regardless of whether some radiative forcing threshold has been exceeded.
Of course the people who publish that graph know this very well. But they also know that 95% of the population doesn't have a clue about laws of thermodynamics and calculus. So why would they push such misinformation on the uneducated masses? I think you can figure the answer to that yourself.
Ratking said:I'm not trying to spam down this tread, but it is a good way of documenting links and interesting articles.
http://www.telegraph.co.uk/news/earth/11912242/Britains-commitment-to-climate-aid-is-immoral.html
The two articles below talks about how an increase in co2 will help plants to grow stronger faster. That will help the food production all over the world. I don't understand how people brand co2 as a polluting gas, when it is essential for life. Even an increase from what we have today is helpful. Especially considered that the sun is going in to a period of less radiation.
http://wattsupwiththat.com/2015/10/...y-co2-improves-tree-growth-drought-tolerance/
http://joannenova.com.au/2015/10/bu...ive-longer-why-we-urgently-need-to-raise-co2/
You know there is no conclusive evidence that it happened in that sequence.As more co2 entered the atmosphere and the Earth got warmer,
Amusing...Ratking said:It seems like changes int the arctics have happened before, for under 100 years ago. But politicians visiting the arctic today shouts doomsday without hesitating
http://docs.lib.noaa.gov/rescue/mwr/050/mwr-050-11-0589a.pdf
jimw1960 said:Ratking said:It seems like changes int the arctics have happened before, for under 100 years ago. But politicians visiting the arctic today shouts doomsday without hesitating
Yes, they were noticing changes to the arctic due to warming over 100 years ago. That warming and associated changes have continued to this day at an accelerating rate, albiet with some noise in the signal that allows deniers to cherry pick data to claim it is actually cooling. I was up in Alaska last year and visited exit glacier. On the road into the park there are signs showing where the glacier terminated back in 1900, 1930, 1960, etc. to where it is now retreating up the hillside to where it originates from the Harding Ice Field. This is just one example of thousands around the world. The worlds ice sheets are losing volume at an estimated rate of 500 cubic kilometers per year.
Frankly, I don't see how you can continue to cling to the idea that you can add 30 billion tons of a greenhouse gas with known properties to the atmosphere and not have a warming effect. It is simple physics and not that difficult to model. You decrease the amount of incoming solar radiation that gets reflected back to space and something has to get warmer. Where modeling gets complicated is in how that additional stored energy gets distributed around the planet. Most of the heat gets absorbed by the oceans, which by the way reduces its capacity to take up CO2.
