Ok, so a little background. My dad found a couple refurbished Homelite cordless lawnmowers (a UT13222 and a UT13126) this weekend (at a Habitat for Humanity ReStore if anyone's familiar with those) for $50 each, so since he's in the market for a new lawnmower and I want to get an electric one...and since they normally retail for $300-350...I convinced him to pick them up.
The one catch is that neither has a charger. I know, not a big problem. For now, I told him to just open up the battery case, disconnect the batteries (24V20Ah SLA, I'm assuming two 12V 20Ah in series), and use his car battery charger on each separately. Even picking up an official Homelite charger for these would only bring them to ~$100 each, which is still a bargain.
Still though, that SLA is only going to last so long under lawnmower abuse. I'm going to be converting mine to use a 6S LiPo pack (the mowers are 24V) in a removable unit that I can repurpose to run other equipment (that I don't have yet..but I'm going to be getting or converting an electric weedwhacker at least) and just charge it with my iCharger, but for his I want something a bit more idiot-proof (not that he's an idiot, but you know what I mean).
Now, I'll have to do some testing to confirm, but I'm guessing that a 10Ah lithium pack would do just fine for his yard. They have a ~0.75acre wooded lot, but there's not really much grass on it. I'd say maybe ~0.25acre of thin grass, max. So, I'm thinking for his pack, probably 7S1P 10Ah (or 14Ah if 10 looks like it won't be enough) HiPower LiFePO4, for the long cycle life and peace of mind, and since he won't be using the pack anywhere else, the extra bulk doesn't really matter. It should still fit just fine in the old SLA battery pack enclosure. I think he's going to be picking up an official charger for his, so I'm thinking that will probably work fine to bulk-charge the LiFePO4 pack (might need a little tweeking, idk, we'll see once I can examine one instead of just reading online descriptions), but for keeping it balanced, I don't want him to have to worry about having to check anything, so I want to put in a simple BMS.
So now we come to the real question. For a zero-maintenance pack a 2-hour drive away from me if it ever breaks, what would you all recommend for a BMS? For context, I'm perfectly comfortable building my own electronics.
And before someone mentions it, yes, I am aware that Ping makes a 24V pack in 10Ah and 15Ah sizes, but since the HiPower cells come out to ~$100 less for each size (before shipping for both), I'd rather go with those and build the pack myself unless the circuitry to make it bulletproof is prohibitively expensive.
