zukster said:I just read that Wurth Film is a silicone dielectric spray.
That gives me the idea of opening up my motor, packing it with silicone dielectric grease ,
the closing it up to lock it in. Its pretty cheap at Canadian Tire, or I wouldn't consider it.
7 dollars for a 85 gram tube of Permatex Dielectric Tune-Up grease, which I verified is
silicon based.
That should stay in there a while without needing to drill a hole at all.
grindz145 said:I believe that the grease would not stay in well especially when heated. Also, since it is not perfectly sealed, the grease will get fouled with other junk that you don't want in there (salt perhaps?)-Troy
You guys just don't get it do you? Wurth film is not a silicone or is it dielectric.zukster said:I just read that Wurth Film is a silicone dielectric spray.
silicon based.
is totally useless unless you are methods and your hub generates 100 degrees+ celcius of heat to melt it to liquid. Can you boil water on your hub motor during the winter?7 dollars for a 85 gram tube of Permatex Dielectric Tune-Up grease
The hole is ideal for periodic maintenace without dissasembling your bike.That should stay in there a while without needing to drill a hole at all
Affliction said:Wurth film is not a silicone or is it dielectric.It is a pure base petrolium which coats and adheres to metal surfaces to prevent corrosion long term. It is semi fluid which means it flows SLOWLY but never solidifys. Ideal product for hub motors.
Drunkskunk said:problems I see are:
The break down of the insulation and glue due to the solvent action of the grease
Drunkskunk said:Friction caused by the grease viscosity acting on the airgap. Oil is a lube only when the viscosity is overcome, untill then it sticks things together pretty well. The airgap is so small, and grease is so well effective against shearing, that it would be difficult to spin the motor efficently.
Drunkskunk said:Weight. it woudl take a couple pounds of grease to fill one of these things.
Drunkskunk said:and last of all, Leaks. Grease is a fluid, more so when hot. if the seals can't keep water out, they can't keep the oils from the grease in. This bike would leak more than an MG, and sling grease as the tire spun.
Affliction said:Permatex Dielectric Tune-Up grease...is totally useless unless you are methods and your hub generates 100 degrees+ celcius of heat to melt it to liquid.
Affliction said:zuckster you have a bafang; I had to look it up. As it's a geared hub then you need something that will keep the gears greased.
Disregard my crappy tire suggestions for your application. They were good for direct drive hub motors.
http://www.wurthcanada.com/ Contact them, I'm sure there is a distributor in your area and you can buy a can of Wurth Film.
They ship by purolator right to your home. I've tried many types of lubes because I work at a transmission shop and this stuff is on the shelf.
This stuff is like grease yet still fluid and it doesn't wash off in water spray! I even have an E-bike shop using it to lube hub motors after repair and they now swear by it because it prevents so many hall sensor failure comebacks. http://www.ridemore.ca
Julez said:All these fancy anti-corrosion sprays pretty much consinst of the same thing, which is penetrating oil. Get a cheap can from eBay, or any hardware store.
I gave my Crystalyte stator a really good spray from all sides, so that it was dripping wet all the way through.
When I reassembled my motor, I applied isobutyl caoutchouc all over the flanges. It is a messy black goo, which has the advantage of staying messy. It does not dry out, it always keeps its pasty state.
This way, no water can enter here.
Affliction said:http://www.wurthcanada.com/ Contact them, I'm sure there is a distributor in your area and you can buy a can of Wurth Film.
zukster said:Hey Affliction (Is that your real name ? :lol: ), when I emailed wurth re they wrote,
Unfortunately we do not sell to the retail sector. Our packaging is not consumer labeled.
Preston Emerson
District Sales Manager GVA-C1
Wurth Canada Limited
Email: pemerson@wurth.ca
Where did you get yours from? Maybe they'll ship here too.
I'd rather have this shushing around in my hub than rusty water. Vancouver is also known as the Lower Rain Land.
If it was not 24/7 of rain here for weeks on end, I'd just stick with the grease, as John in CR suggests. Also, this is
for a motor that is being run by a sensorless controller, because the halls shorted out. So no worries about those
pesky little wires in this case.
Affliction said:Maybe Justin at ebikes.ca can get you some since you're in Vancouver.
I've found the solution to this as well by spraying the controller board with Ignition Protector and this is avaliable at Canadian Tire.
It coats the board and all components in a permanent plastic film.
Don't spray connectors with this! You'll never be able to unplug them again because they are glued solid
I showed Justin some of this stuff when he was in Ottawa on his cross Canada ride. Ben from Ottawa....
zukster said:I'd rather have this shushing around in my hub than rusty water. Vancouver is also known as the Lower Rain Land.
Where is CR John? Definitely not in Canada that's for sure. Ventillating a hub motor for daily road use in Canadian conditions is a definate NO-NO!John in CR said:Epoxy paint on the steel and some drain holes at the perimeter then. Once I go sensorless, then I'll definitely go nicely ventilated too, with some way to prevent debris entering at the intake. Angled exhaust vents will prevent debris entering there and force water out immediately. For a motor expecting lots of rain use, I'd limit the exhaust/drain vents to very narrow slits so as little muddy water enters as possible.
Once you accept that water is likely to get in, then you just want to protect the steel from rust, and give the water a way out too. I wish I didn't have halls to worry about.
John
zukster said:Affliction said:Maybe Justin at ebikes.ca can get you some since you're in Vancouver.
I've kinda bugged Justin a lot as of late, but maybe he'd want to try it for some of their motors too. For the controller
boards I got some MGChemicals Silicone Conformal Coating spray, but its pretty much the same thing as the CT
Ignition Protector spray. I've used it on my car. Good too know the CT stuff works. Its prob a lot cheaper. The MG
stuff was 18 bucks for a 340/12oz can. So you have not needed to pot the controller after spraying? That would be
the next ultimate step. I might try to spec out something similar to that Wurth Film that's easier to find. Maybe
that ACF-50 that was mentioned above.
edit: The ACF-50 looks to be mainly sold in the UK. It might even be Wurth Film (or similar) branded for resale.
This is good shit!It is superior anti-corrosion compound.
It kills corrosion in progress
It prevents new corrosion cells from forming for 12-18 months
It is an excellent penetrant.
It is an excellent light lubricant.
grindz145 said:I plan on using ACF 50 on my motorcycle this winter as well. I think this may be a good bet on the hub motor as well. I still like the small hole idea for re-spraying whatever the corrosion inhibiting agent may be.
Affliction said:I'd definately use it if it was availabe in Canukistan![]()
