so a 8P10S would be a total of 80 cells?
what I did is use total 20 cells, each was still good at over 4 volts, then put 2 each in parallel..like this
then soldered the pairs together on tops and bottoms, then a thick jumper cross ways on top + to - then bottom - to + etc, snaking across the pack.
of course spot welder/nickel tabs are best but I dont have one. seems to have worked out ok, limited time spent with the iron on the cells, used lots of flux and made a square tip with the cells. Then put the BMS sense wires to each cell.
but if I went like this
_ _ _ _ _ _ _ _
etc.....
for a total of 80 cells in 10S config, would that work?
for the present 10S2P pack, I have a relay and code for the arduino so when one pack is under 32V, the nano switches the relay and I can use another pack (not built yet) ,but just wondering for a new pack build, how far I can push it. 80 cells is allot of capacity and range!
