atcspaul
i got this from walmart.com http://www.walmart.com/ip/Folding-Bike-Stand/13012494. less then $20.00 shipped to the virgin islands and will only be around $18.00 to have shipped to store for you all that have access to a walmart. i redid the stand a little. i drilled 2 small holes in each corner of the stand and ran old brake cables thru them then put cable stops on them. on the end i put a cable crimp so i don't worry about fraying. results are better then i imagined. i can put the bike on their and run it at full throttle or pedal and adjust the gears work on the brakes ect. i can do this with battery and all the accessories on the bike. weight is not a factor. it is amazingly stable. the first picture is stand before i put on the cables. i have it adjusted to hold the rear tire about 4" of the ground. the second picture is how i put the brake cables on it for good stability. i can adjust how high the bike is off the ground with the cable stops.
