info on Bisida BMS brand
niels_
🧲 New user
Building a 24s3p LiFePO4 Battery – BMS Advice Needed
Hi everyone,
I'm planning to build a 24s3p battery pack using recycled 26650 LiFePO4 cells. Each cell can deliver 30A continuously. I’m considering using the following BMS
the 24s 50A 3.2V version:
🔗 AliExpress BMS Link
This pack will be used to power a pocket bike with a 1600W hub motor and an 80A controller. So under full load, I’ll be drawing up to 80A from the battery. Since I’m only planning to use the battery in this setup, I’m wondering:
Will this 50A BMS be sufficient, or is it likely to fail under this load?
Has anyone here used BMS units from the brand Bisida? The product description on AliExpress claims it can handle 3 to 5 times its rated current as peak current – but it doesn’t say how long it can sustain that. Any real-world experience or data about these would be super helpful.
I know there are more advanced (and probably safer) smart BMS options out there, but I’m trying to keep the budget as low as possible for now.
Thanks in advance for any help or insights!
Don't have any recommendations for an alternate, but I would increase the BMS budget. It's the brain of your battery. Give it a good one. Why compromise safety to save 25 bucks?
I’ll be riding it on public roads, and I expect there’s a good chance I’ll get stopped and the build might get confiscated (this is in Belgium). So for a battery that I’ll probably end up losing anyway, I don’t want to invest too much money, therefore the budget conscious approach 😅.
