buchhla
Hi all, I am in the process of trying to install a Q128C based system from BMS Battery on my road bike. I have been going back and forth with BMS Battery and have kind of hit a wall. My bike uses 2006 era Shimano 105 Hollowtech cranks and matching bottom bracket. I enlarged the center hold on the magnet disk so it would fit on the 25mm shaft, but I don't have the clearance between the crank and the bottom bracket itself for the magnet disc.
ie, when I install the crank, the disc is deformed from the crank pressing on the disk the the pedals don't want to turn. I see a few other companies sell discs that attach to the small chain ring on the other side, which looks like it might work, but I don't see a source for these in the US, just china or the UK/DE so I want to know this will actually work before I spend time and money trying it.
I didn't take a photo with the disc installed, but I have some of the general area showing the lack of clearance. Am I missing something, or do I need a different setup?
