DufferDave7
New here
I'm looking to purchase a used tandem and then add a motor. The setup will be an adult up front and a child in the back and a tag-along attached at the rear. It will be used on a variety of terrain, but I live in the Rocky Mountains, so there will be plenty of hills. I'm also not a bike expert, but am an engineer who can usually figure things out. However, I don't want to be having to do things like machine custom parts. I want something I can do in a day.
I'm trying to figure out both a good motor setup and a tandem that will work well with that. The information I've read is all over the place, but obviously there are three general motor approaches.
Front hub - wildly varying opinions. A lot of folks comment about potential torque issues as well as front fork strain. However, it seems that most of those who have actually tried this setup have not had problems.
Rear hub - I haven't read about many folks who went this route, but it seems like it would be a reasonable approach.
Mid-drive - Seems to be the best performance option. However, install reports range from slightly tricky to "thankfully I work at a welding and metal fabrication shop". The biggest issue seems to be motor clearance with a left side timing chain. If I can find a tandem with a right side timing chain option it seems like it should be pretty straight forward. But finding a used tandem with a child height rear seat and right timing chain is difficult. I also haven't been able to find exact specs, like you need X mm distance from bottom bracket to left sprocket to fit a BBSHD. That sort of information would be very valuable.
Any thoughts on general approach as well as specific motor suggestions? Thanks.
