IBScootn
Doctorbass, thanks - i'll get those probes.
Gregb said:why not just use a diode bridge to protect your meter or put a diode in series with the lead until you have checked it??
999zip999 said:I haven't got the pogo points yet.
texaspyro said:999zip999 said:I haven't got the pogo points yet.
Just short the meter probes together to get a "tare" reading. Subtract this from the cell readings to get a more accurate cell reading.
999zip999 said:I'm getting 15.2- 21 on my meter with some 23 and up where should I stop on the upper limit to match the low res. cells ? What are the readings other people are getting on there konion cells ? What are the I.R. limit ?
999zip999 said:Can I add 6in. of wire between the pogo points ?
Kin said:So, I think Doc said this wasn't a particularly sophisticated IR tester design. I was trying to figure out- how does it work? It is simply a resistor and voltmeter setup [I'm not sure with two leads how it would put something in both series and paralleled, but yeah). Just wondering if anyone had a quick explanation.
IBScootn said:Kin said:So, I think Doc said this wasn't a particularly sophisticated IR tester design. I was trying to figure out- how does it work? It is simply a resistor and voltmeter setup [I'm not sure with two leads how it would put something in both series and paralleled, but yeah). Just wondering if anyone had a quick explanation.
Kin, read this re 4-wire measurement:
http://www.cirris.com/testing/resistance/fourwire.html
