Hi
I want to convert my Felt DD70 to electric, I would like to use the Bafang 750w rear motor for it, but the problem I have with is with the axle. I would prefer to use this drive over the mid drive as I was to try to keep it looking like an e-bike as best I can. Unlike most bikes the DD70 do not have rear lugs which you slide the wheel onto. Instead it has a large 12mm skewer that fits straight through the hub and screws into a threaded hole on the derailleur side. I have had a look around but cannot find an exploded view of the drive, can the axle be replaced, or is it pretty much a fixed item? If it cannot then I am pretty confident that I can pull the rear forks wide enough to place the wheel in, but them I have a 8mm axel going into a 12mm hole so would using a sleeve be possible, the total length of the current skewer is approx 220mm. I have included a couple of pictures to explain it a bit better.
If it comes to it I will fit a mid drive, but as I sad previously i prefer the stealth look of the rear hub, especially as the bike will have a rack and panniers fitted.
