In my 48volt setup I used 10AWG wire throughout. I think that was a huge waste.
Here are the Continuous amp ratings for different wires
20AWG 15 Amps
18AWG 20 Amps
16AWG 35Amps
14AWG 60 Amps
12AWG 90 Amps
10AWG 150 Amps
8AWG 200 Amps
I would say that on a 48volt 30Amps setup that I use. Having 12s4p setup, it should only draw from each paralleled batteries about 8 amps each at the max.
This means I should get away with the main battery line being 16AWG, and the wires connecting the different batteries 20AWG and I would never go over the rated amps usage from the batteries. Remember those are continuous ratings so most likely it can handle a higher peak, also you most likely will never be drawing the max amp from the batteries so most of the time you will be far below a 30 amp draw.
Say you have a higher end setup and are drawing 100 amps. In a 4p setup (max draw 25amps from each paralleled batteries) you should be able to get away with 16AWG wires connecting your parralel packs and have a 10AWG (probably be OK with 12AWG wire) wire as your main battery wire.
I know from various hobbies that people like to go overboard with things. Like computer cooling etc., When it seems that it is mostly a waste. SInce I am using 10AWG wire for my complete 12s4p setup, that was a total waste of money and space inside my battery bag to use such heavy wires. Not only was it a waste but soldering those 10AWG wires into small connectors was a big pain, especially considering 4mm bullet connectors do not fit over 10AWG wire.
You may say that well, it is not much more money etc. But I would have easily made my parallel harness double the size to make it easier to connect my batteries if I was using much cheaper and smaller AWG wire.
I would like to know what people think about this and if the reality of it is that most people waste money on oversizing the AWG wire as they really do not need to.
20AWG 15 Amps
18AWG 20 Amps
16AWG 35Amps
14AWG 60 Amps
12AWG 90 Amps
10AWG 150 Amps
8AWG 200 Amps
